1.5.0 issue
    Denoise + sharpen (use default) caused pink blobs on resulting image (see enclosed)
  2. Your system profile
    Macbook Pro 2021 M1 32GB
    2023-08-06-13-50-53.tzlog (116.4 KB)
Thanks for reaching out. This is a known bug with the Remove Noise - Raw Normal model.
To avoid this, please increase the strength sider to 10 or higher.
We are updating the Remove Noise - Raw models to prevent this behavior very soon.
