On the topic of cropping in general; there doesnât seem to be an option of cropping and straightening. What is the point of having a crop tool if one canât also do this? If there is the option to do this could someone please explain how you can do this please? Thank you.
Same here, also M1 Max. Cropping and especially also gigapixeling results in a crop being transferred to LrC that has nothing to do with the actual crop made.
Have the same problem with cropping in the 1.3.3 update using Windows in both Stand Alone and Lightroom Plugin. No matter where I crop in the preview, it always gives the top left corner of the original image.
I am using my iMac. When I send the raw photo from LRC to the plugin and crop it, the file returns to LRC with the wrong part of the photo in the crop.
@Benjamin@morusth@frank.topel@robert.mckee@wcaswell44
This crop issue is fixed in the update releasing today. Please update to v1.3.4 and it should be working as expected again. We found it the day after and added a fix.
When I crop now I see no change in the preview image when I press the apply button and no change in the resolution of the image and no change when I return to lightroom. So, looks like it NOT cropping in photo AI 1.3.2
Lightroom 12.3
I understand that in version 1.3.2 that the Crop feature is in Public beta test. When trying to use it, the cropping feature seems to work, but the photo is not cropped after hitting âApplyâ. Is this part of the beta test?
I have encountered a similar problem with release 1.3.2. When I try to use the crop feature when using the plugin from Lightroom Classic, it doesnât actually crop. When I try to use the crop feature from the standalone version it crops in the wrong place (ie the output file is a crop in from some other part of the image, not where I specified.
BTW, I agree the crop is not in beta. I have been using it successfully in previous releases, though i canât say if 1.3.1 worked ok, because i did the update from 1.3.0 to 1.3.2 in one go â ie both updates together.
