When trying to upscale one specific image (smiths-rank.jpg, provided below), Photo AI v1.3.11 produces very strange, colorful artifacts if noise removal is activated with Normal or Strong models. The artifacts aren’t present if Extreme model or no noise removal is selected.
Steps to reproduce issue:
Load “smiths-rank.jpg” image in Photo AI v1.3.11 and let the app calculate the Autopilot settings.
Set the Enhance Resolution model and the output resolution to whatever you please.
Activate the Remove Noise toggle and choose Normal or Strong models. The bug will manifest.
Choose Extreme noise removal model and the app works as expected.
P.S.: I don’t if the image provided will be reencoded or not. So, let me know if I should upload in another place, so you can reproduce the bug for yourselves.
The input file has a checkerboard pattern that we did not train the model to handle. This is causing an artifact with the Remove Noise - Normal and Strong models.
